Using Law Curves
Using Law Curves
What is the procedure for using the law curve method for blends. I created a sketch for the law curve but not sure if it must be the exact length of the perimeter being blended. I'm not sure which items UG NX2 is asking to select. Also, what are some examples for using law curves in general as opposed to other methods?.
Thanks in advance
Enduro99
Thanks in advance
Enduro99
RE: Using Law Curves
Note that you can use a sketch as a law curve.
Using G1, G2 curves as law gets you a very smooth variable blend.
Does NX allow Edge blend to be variable and is this option availible for V18?
Michael
Yes edge blends can be variable (at least as far back as V15 - the first version I started using). Look up 'variable blend' in the modeling help files, it will explain the procedure better than I can in a simple post.
