Pull down menu - Combo box
Hi all, I have another question which I think some of you guys can halp me with.
I wanna create pull down menu or combo box with multiple entries. For example I wanna create spreadsheet with daily working hours for each day ie I am trying to put up a combo box with the names of all employees, so that we don't have to type their names each time, but just select name from the combo box.
Any clues what would be the easiest way to do that.
RE: Pull down menu - Combo box
I think what you should probably use is the standard Excel Data|Validation menu. Just have your staff names listed (in a named range, for instance) and apply Data Validation to the cells. Look up Excel help on "data validation" for more details.
Brian
Create your combox box, then right on it to display properties. You will see a property called ListFillRange. This is where you can enter the range of cells you want the combo box to show selections. For example, if all your names are in cells A1 to A20, then this property can be set to that range of cells. I prefer to create a named range and use that name for the ListFillRange property.
Thanks again
Jimmy
