Synchronous motor question
Fellow members, I am a Mechanical engineer, who has to deal with motors attached to mechanical devices, and who knows just enough to be dangerous about motors. I have even posted to threads in this forum.
However, one thing I cannot remember from my old college days is the difference between induction motors, (which I have a lot of familiarity with) and synchronous motors, which I encounter from time to time in small fractional HP as well as 1-10 HP ranges.
I have looked in all the text books and reference books I have in my possession, as well as googling the words. Still I don't know what I would like to know about synchronous motors. Differences, advantages, disadvantages, etc.
I'll bet you electrical types can straighten me out.
RE: Synchronous motor question
1. M.G. Say "Alternating Current Machines"
2. S. R. Slemon "Magnetoelectric Devices, Transducers, Transformers, and Machines"
3. A. E. Fitzgerald, Charles Kingsley, Jr., Stephen D. Umans "Electric Machinery"
4. Etc.
Differences: Asynchronous motor runs with slip, does not have field winding supplied by a power source called "Exciter", has a different speed - torque characteristics, it is less expensive, etc.
Advantages: Asynchronous motor is simpler and rugged, less expensive, cannot drop out of synchronism, is often simply started with Direct On Line (DOL) start, etc.
Disadvantages: Asynchronous motors usually do not power very high HP loads, experience slip, tend to burn rather than drop out of synchronism and stop, etc.
Also, visit technical library and read various Encyclopedia, Technical Dictionary, and popular magazines/journals similar to popular mechanics.
Sync motor operates at syncronous speed. A loaded induction motor operates slightly below sync speed.
Sync motor is a little more complex. There is more to maintain and more to fail.
Sync motor power factor can be adjusted. This is an advantage particularly for low-speed motors where induction motor tends to have very bad power factor.
Therefore sync motors are sometimes selected for low-speed high horsepower applications.
Lots more info at
http://www.geindustrial.com/products/reference/GEZ-6209.pdf
The synchronous motor has constant speed from no load to full load or until it is pulled out of synchronism, that speed is exactly 120*Line Frequency/Poles.
Synchronous motors can be applied to very large loads of constant type achieving high efficiency and adjustable power factor. One disadvantage of synchronous motors is the lack of accelerating
Torque, then auxiliary windings or pony motors are required to start.
-price (magnets are pretty expensive)
-overheating them can destroy magnets
-if you are not experinenced with handling of them you can usually dissasemble them only twice - first and last at once
Jacek
Do it right or don't do it at all.
http://labs.ee.psu.edu/labs/powerlab/papers/energy_00154.pdf
http://www.polito.it/syncrodrive/aquila/Report_Aquila.pdf
etc. for more info on pmsm and their attractive characteristics, e.g. high power factor, absense of field losses.
The synchronous motors are usually convenient to apply to very large loads, e.g. over 10000HP.
The synchronous motor is more expensive than the induction motor; however, it runs at higher efficiency than the induction motor.
Don't they? I've worked with 2MW synch and 2MW induction motors and the synch motors had less starting current in the same application. Is this an aberation?
You might be right. The starting current for sync motors is inversely proportional to p.u. value of its sub-transient reactance Xd", so if this value in your case was 0.2 the starting current could be 5 times of rated.
Do concepts like the reactive power issue, which I actually understand a little, have any real affect in that small HP range. What I know about the motors that I have in mind in asking the question above, is that they are slow speed, and draw very little current, and can drive into a stall and not burn up very rapidly, (if at all-and that is in question in my application.).
I have already noted above that the reference information readily available to me has failed me on the topic, and the nearest technical library at an engineering university, or such, is some distance away, so I was hoping to get answers and input from peers, rather than having to make the trip.
rmw
The downside is usually cost (significantly higher) and off-the-shelf availability (significantly lower) in one-off applications compared to the ubiquitous induction motor. You will however find synchronous motors more often in OEM applications because the cost and availability issues then become negotiating points.
If you are going to need adjustable speed, the latest generation of vector control drives for induction motors makes synch motors less attractive unless again, slow motor speeds without forced cooling are necessary. They are also less valuable in high speed applications and/or those where output shaft speed is lowered through a gearbox in order to multiply torque, because in most cases you may as well use an induction motor anyway.
Once you get into high HP and power factor issues, they become attractive again, but for different reasons.
Was this what you were looking for?
"Venditori de oleum-vipera non vigere excordis populi"
That is a very comprehensive review. Thank you. Other comments in the thread helped too. I did remember some basic facts regarding synchronous motors from an electrical machinery course I had to take in college. But, what I remembered was pretty sparse. This helps. Thanks.
rmw
Not sure if I'm just mis-reading your post here -
By simply controlling the field strength, either with permanent magnets or slip rings on the rotor, a specific speed can be accurately maintained with relatively high torque for the physical size."
How does control of the field strength determine motor speed? Stator frequency governs the speed of a synchronous machine; field strength can be used to vary the speed of a DC machine.
For mains-supplied application, synchronous machines are fixed-speed drives. They normally rotate slightly faster than the equivalent induction machine because the synchronous machine rotates at a speed determined by the supply frequency, while the induction machine rotates at a slightly lower speed - it 'slips' relative to the supply. If an induction motor was going faster than the equivalent synchronous motor, it would in fact be a generator!
If we learn from our mistakes,
I'm getting a great education!
Hmmm, I can't believe I wrote that...
This is one of those times when you learn how someone else read your words and you see the completely different and unintended viewpoint they can get from it. My bad.
The intent behind that statement was not to imply that changing field strength changes speed (although I DID apparently say that). It was meant more as a design issue in either selecting the PM or the field coil design. Sorry to be misleading, thanks for pointing it out.
For you that are contributing to this thread, how does this discussion pertain to the 1-10 HP synchronous motors that I mentioned in the thread starter. Remember that it is a ME asking the question, so you have to try to couch your answers in such a way that it is understandable to someone outside your disipline.
///Visit for synchronous machines problems and solutions:
http://edt.uow.edu.au/indulkar/chap02.pdf
for a little brain gymnastics around those solved examples.\\\
Thanks for the link, but that is way beyond what this Mechanical Engineering brain can stand to be teased.
Thanks anyway, though.
rmw
