Motor buzz
Motor buzz
Motor buzz
I have a motor which buzzes and turns slowly.  It had a bad capacitor which I replaced with a very old one of the same capacitance and tests good(not shorted or open) except I cannot test the leakage current and don't know what it should be.
Would a capacitor with too high leakage cause this, or has a coil burnt out.
P.S. It is out of a small "Little Giant" magnetic drive water pump
Ben Englund
RE: Motor buzz
Suggestion: Please, post nameplate data
RE: Motor buzz
The pump is a Little Giant 4-MD-SC
thermally protected,open,fan cooled
permanent split capacitor motor
.1 HP
115VAC
60 HZ
1.7 AMPS
185 WATTS
RE: Motor buzz
Testing of small ac capacitor.
It is a small ac capacitor and with this size, I would simply use a 250V or 500V insulation tester(Megger) to test for its dielectric property.
RE: Motor buzz
Suggestion: A dc power supply about 100VDC to 150VDC and a suitably ranged ammeter will measure the capacitor leakage current.
