Co2 Storage Tank
Co2 Storage Tank
Design pressures of co2 storage tanks are usually set at 350 psig.But in tropical countries ambient temperature goes as high as 115 deg F. w/resulting vapor pressure will be more than 900 psi. Can we rely on refrigeration to prevent over pressure? How do we determine capacity of refrigeration system.
RE: Co2 Storage Tank
for delivery of Co2? Each case is a new optimization problem. Are high flow rates involved? This changes thermal exchange requirements drastically. More information is needed to bracket an answer. I agree with butelja above on safety. Loss of the contents of a tank is generally cheaper than loss of a tank because of its contents. Relief valves can be doubled up and inspected periodically and are a cheap form of insurance.
Looks like an easy task.
