aluminum treadplate
aluminum treadplate
aluminum treadplate
I need to know the moment of inertia perpendicular the the face of an aluminum plate that is 1/8" thick and 48" wide.
I can't find any info anywhere.
thanks
RE: aluminum treadplate
For a rectangular section, the moment of inertia is (1/12)*b*h^3, where b is the plate dimension parallel to, and h is the dimension perpendicular to, the axis about which the moment of inertia is being calculated.
I am not clear from your message as to about which axis you are calculculating the moment of inertia.
I hope this helps.
b*d^3 / 12
AISC recommends contacting the supplier for mechanical properties/physical properties.
The Aluminum Association publishes allowable loads for tread plate
