Shoulder Material and Specifications
I, again, am looking to my esteemed colleagues to assisting me put together a small database with respect to shoulder material requirements (unpaved) for national/interstate highways, state highways. In particular, I am looking for details as to Plasticity Index limitations, gradation specs, crushed and/or natural, stabilized (e.g., lime), requirement for turfing, etc. My thanks to all.
RE: Shoulder Material and Specifications
Where are your "Danger Soft Shoulder" signs?
I couldn’t help myself.
Frivolity aside good luck in your endeavor.
Since the embankmant/roadway is constructed as a unit, the material for the shoulders should be the same as the roadway.
Tincan
http://www.kytc.state.ky.us/construction/Spec2000/toc.html
http://www.dot.state.pa.us/Internet/hwyIntHS.nsf/frmBDesign?OpenFrameSet&Frame=contents&Src=_t5t4mst35e9n6at1fd1rniibeeh456bjeedj2ui3fdlil0ob7ckq30e31dpi3efqfe1imshjfe9micgblehnkcsj1dlim80_
http://www.tdot.state.tn.us/construction/specbook/95sec300.pdf
http://www.tdot.state.tn.us/construction/specbook/95sec400.pdf
http://www.tdot.state.tn.us/construction/specbook/95sec500.pdf
http://www.tdot.state.tn.us/construction/specs.htm
Rockjoint
rockjoint@yahoo.com
http://www.dot.state.az.us/ABOUT/cns/index.htm
