faster than light
faster than light
It is a commonly taught that the phase velocity propogates at a velocity > the speed of light in waveguide systems. However, with the caviot that the information travels at the "group velocity", which is equal to or slower that the speed of light.
Question? by using multiple channels or waveguides, quantum detection and combinational logic, could an effective information "packet" be synthesised from the combination of phase velocity transmitted energy? and faster than the conventional group velocity.
The application is be encription keys that are imbedded into leading edges of com signals.
RE: faster than light
Regardless of the phase velocity, when you change the modulation at the sending end, the modulation will not reach the other end faster than the speed of light.
You may be aware of real time scopes where the write speed across the screen exceeds the speed of light. Nothing is travelling faster than the speed of light of course, its just that the beam appears to be going that fast.
6.28 million miles per sec.
The phase velocity is not real - it is comparing the
peak times at different places like the different light spots at differen places -- motion would mean the SAME
light spor or amplitude moving.
<nbucska@pcperipherals.com>
Please try to quell your annoyance because you did not understand the answer. We are freely giving our time and there is no need to be rude.
Say there are two points on nbuska's circle. A and B. Point A makes precise position measurements. Point B make precise velocity measurements.
The precise position measurements at A also, strange enough, affect the bullet's velocity that are behind it as well, if the source is well known. Like predicting a bullets fly out to compute lead angle. The precision on the A point position accuracy is modulated-- modulating the velocity of the ones behind.
The velocity meter at point B detects this modulation (information)
Sometimes you need to kick a donkey to get it's attention.
Better wake up humans, we're coming!....
... to the end of another lame april fools joke.
Stars to logbook and nbucska.
nbucska, xyzzy was a magic word on the old unix main frame text based game adv(enture) that we engineers would play when knowbody was looking.
I had played ADV -- still don't get the reference...
A better "Gedankenexperimente ":
From a plane I observe the trafic on Hwy 267. South of
Longont CO I see a schoolbus northbound.
2 minutes later and 10 miles north from this point
I see the/(a) schoolbus.
The speed is 10/(2/60) = 300 MPH.
Gedankenexperimente ": german?, definately not spanish.
Ukrainian Proverb;" In every joke there is a truth"
A wave hits a beach at an angle, the the velocity at which the wavefront intersects the beach is faster than the velocity of the wave front normal to it's propogation vector. QUARK! phase velocity!
Can a disturbance at the instant this wavefront "hits" the beach propogate parallel the wavefront, along the crest?
This disturbance travels along the wavefront. The effect of the disturbance travels a physical distance farther than the actual distance traveled by the wavefront! Quark! a disturbance on the phase velocity!
xyzzy was a magic word that got you out of closed dark caves/traps. It did not always work.
My guess is that you got stuck and died in alot of those dark cold caves.
(I did also, as I said, it did not always work).
I recall reading about a group of physicists (in Germany, I think) who managed to send a (Beethoven's 5th) signal faster than light. The concept was to use quantum tunneling of electrons through a copper sheet, but the result was hotly debated. I am not sure of the current status of that experiment.
This does rather strike a chord though. Using only Maxwell's equations (which are after all the foundation of relativity), only v<c siganls are possible. In order for anything to have any chance of travelling faster than light requires a quantum style solution.
Don't get me wrong (I'm convinced string theory, or even membrane theory will eventually prove to be resonances in spacetime), I'm not saying the solution will require spooky quantum laws. I'm just saying that we will need to understand quantum mechanics better before we can try stuff like this.
Still, good to think outside the box...
Mart
http://www.intalek.com/Index/Projects/References/glossary1.pdf
Towards the end of the entry, it mentions the quantum tunnelling experiment - apparently the signal can travel at 4c!! It also seems to substantiate the point I made about the need to understand and manipulate quantum physics in order to escape the light cone. This interests me, since I am curious, like many, about what sort of engineering could carry us (as well as our signals) to the stars...
Mart
Mart
Mart
I better lie low for a while, of late I feel that they have been watching me.
Hehehe. I gave up ages ago and just smile a lot for the cams...
I like your Quantum repeater idea. I don't think I was ever convinced about once only Quantum keys - just sounds good on talk shows!
Mart
<nbucska@pcperipherals DOT com> subj: eng-tips
Instead of a light beam use a hypothetical wire or string.
Makes Nbucska's experiment very correct.
