Electrical Schematic Software
Can anyone help me on selecting a good Electrical Schematic Software. I'm looking to go back and forth between SW and MDT. Probably in dxf or dwg format. Is there an add-on for SW that I can use? Will Visio work?
macduff
macduff
RE: Electrical Schematic Software
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
Also, SW Routing only covers the modeling aspects. If you want nailboard data/ability, that will come in SW Harnessing (at additional cost).
http://www.solidworks.com/pages/news/viewrelease.html?prid=184
Ray Reynolds
"There is no reason anyone would want a computer in their home."
Ken Olson, president, chairman and founder of Digital Equipment Corp., 1977
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
I am not sure why, but the end effect seems a little better than you get manually with inserting an OLE object. There was a joint promotion for 2001 Plus, but for various reasons it didn't catch on.
Otherwise there are 3 or 4 packages from Europe that export DWG files with blocks, which will import very well into your drawing sheets.
DesignSmith
www.DesignSmith-Services.com
Is Visio Technical or Pro pretty accurate as far as the geometry of electrical schematics? Which one do you reccomend to buy?
Thanks for all your input!
Have a great weekend!
I found a copy of Visio 5.0 Tech. Will it work with windows xp and sw 2004?
