[i][b]Hazardous Areas, & Terminal Blocks[/b][/i]
Hi All,
I guess this will be abit long, I'm designing the controls for a regulating station for a Class I Div I location, and all of the inside instrumentation are exiting via a terminal block then going to the control building. my question is :
Can I connect also the field equipment (which is outside the Class I Div 1 area) to the same terminal block (in Class I Div 2), then pull everything through one conduit to the control building?
Or you think that I should have a seperate conduit for field equipments?
Thanks Guys
Thanks Guys
RE: [i][b]Hazardous Areas, & Terminal Blocks[/b][/i]
