Creation of coloured JPEG
I am trying to create a JPEG from a Soldiworks drawing which has shaded/coloured views. When I open the JPEG it is in monochrome and has poor resolution.
From previous experience of creating PDFs, I have discovered that the option for print colour within the page set-up dialogue should be set to "colour/grey scale" if you want a coloured PDF. This setting appears to make no difference when creating a JPEG.
Is it possible to create a coloured JPEG? Are there settings where you can specify the resolution?
RE: Creation of coloured JPEG
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
I run 1600x1200 Res. and 32-bit Color Quality. I just saved a JPEG file directly from SW and it looks great. Not grainy at all.
Try those setting and see if that fixes your problem.
Scott Baugh, CSWP
FAQ731-376
EUANS
What Version & SP of SolidWorks are you using?
I am running SW04 SP1 & have same problem as you with jpg & tif (didn't in SW03).
I have 32bit colour ... resolution is not an issue.
PDF & eDrawings works fine, so I assume it is a glitch in SP1.
Scott Baugh, CSWP
FAQ731-376
Have another coffee
Scott Baugh, CSWP
FAQ731-376
John Richards Sr. Mech. Engr.
Rockwell Collins Flight Dynamics
There are only 10 types of people in the world - those who understand binary and those who don't.
I have seen no evidence changing screen resolution will give more than a 72 dpi screen print. SolidWorks does a .jpg save the same as a screen print.
What resolution are you wanting?
Anyway, because of my resolution settings and the dot pitch of my monitor, I'm able to exceed the standard 72 dpi. I've heard of higher dpi grades (over 100--something like 104 or such).
For what that's worth. ..
Jeff Mowry
Industrial Designhaus, LLC
http://www.industrialdesignhaus.com
Sorry for the delay in responding but I don't work Mondays. I'm runing 2004 sp2.1. Creation of PDFs is always okay, occasionally I have seen e-drawings saving in black & white (size dependent?)
From memory when I last successfully created a coloured JPEG I think I was using SWX 2003.
