Merge two parts??????
In an assembly, I have two parts. I want to combine them both so that it is no longer an assembly, but one part.
HELP!!!!!!!
Paul.
RE: Merge two parts??????
Open the assembly -> Save As, and select "Part" in the selection-box. The only problem is you will lose all your feature-data en the part will consist of 2 imported body's
Grtz, Bouke
Splendid. Thanks Bouke
Can each of the bodies have differenct densities?
Another way of creating a single part from two parts is via the multi-bodies feature.
Open one of the parts, then add/insert the other part to it. This will create a multi-body part. Then use the Combine function to join the parts as one. This way you will not lose the individual feature data.
from (the City of) Barrie, Ontario.
Everyone has a photographic memory. Some just don't have film.
Creigbm
Multibodies in a part cannot have different densities.
If you create a multibody part by inserting a part into another part, the original parts density will be adopted by the inserted part.
If you create a part from an assembly, the densities will be removed from the original parts & a single density only can be applied to the newly created part.
I think that the single density thing is a logical issue.  A PART is a single part even if it is multibodied.  I know some of us use them in lieu of assemblies for our convenience at times, but that's our tough luck.
John Richards Sr. Mech. Engr.
Rockwell Collins Flight Dynamics
There are only 10 types of people in the world - those who understand binary and those who don't.
