ac capacitor VS run capacitor
I need a 4mf capacitor for a small motor. I have a 4mf capacitor that came from an old power supply. It looks just like a motor run capacitor and is rated for more than what I need. Is there any difference between an ac capacitor and a motor run capacitor? Can I use this? Thanks for any help you can give.
Ben Englund
Ben Englund
RE: ac capacitor VS run capacitor
"from an old power supply"?
Hmm.. Just make sure that it can take the motor voltage and ABOVE ALL that it is an AC capacitor and not an electrolytic (has + and - markings on the terminals and will explode).
If it is an AC capacitor and the voltage is OK, then there should not be any problems. Compensation capacitors for flourescent lighting do also work well for single phase 200 - 250 V motors.
Unfortunately I tried it and the motor still does not run. It only buzzes and turns very slowly. If I turn it by hand it turns hard and does not continue turning. Though it seems if I could turn it faster it would continue. Without power to it it turns freely. Could my old capacitor be weak? I tested the capacitor with a meter and it is not shorted or open. Any Ideas? If the start coil was burnt out it should not turn at all by itself should it? How do I check it with only the two capacitor leads and 110 plug cord coming out of the housing? Thanks for your help.
Ben Englund
Gunnar Englund
Sweden
skogsgurra:
My great grandfather Ernie Englund came from Sweden and spoke in swede when he was mad. I believe his parrents brought him over as a young boy. So I guess we could very well be related:>)
It used to be that I did not see any Englunds here in Minnesota, but I am seeing more and more.
What sort of meter did you use, and what were the results? A capacitor should be open when tested with a normal multimeter.
Start each new day with a smile.
Get it over with.
That said..I should have said that the capacitor tested ok although I am not able to test the leakage current.
Regarding capacitor testing, your observations are absolutely correct. Sometimes I find that by asking silly questions, something obvious is picked up.
Another silly question: can you describe how the capacitor and motor windings are connected? What measurements have you made on the motor, and what were the results?
Get it over with.
Ben Englund
Naughty practice, double posting! Someone will red flag that if they are srict.
Third daft question: is the thermal protection definitely ok? Some of these little motors have non-resettable thermal fuses which can be tricky to replace.
Get it over with.
I have no idea if the thermal protection is okay or not. I seem to get a low resistance reading from one coil and a high one(like 500ohms can't remember now) from the other. maybe the thermal protector is shot and causing a higher reading on that coil? Would it be connected to both coils or just one?
NOTE: I'm not sure how the coils are hooked up, I made ohm checks and guessed from there.
Thanks again
Ben Englund
On a PSC motor, the thermal protector is in the 'common' lead, versus the 'run'- and 'aux'-winding lead. It almost always fails catastrophically… not much ”in between.”
Check line voltage at the motor—then line current—then possible mechanical binding [motor off.] Note a ‘cooked’ aroma is the kiss of death.
Ben Englund
http://www.lmphotonics.com/single_phase_m.htm
for various single phase motors and their associated capacitor(s)
http://www.engin.umich.edu/labs/csdl/ME350/motors/ac/induction/1-phase/
for: a bit of single phase motor theory
http://www.gewater.com/pdf/TechNotes/TN%20130%20Evaluating%20Condition%20of%20Single%20Phase%20Submersible%20Mo.pdf
for: motor capacitor test
http://toad.net/~jsmeenen/capacitor.html
for: motor run capacitor test chart
etc. for more info
Ben Englund
Both of those lines are classic signs of BAD BEARINGS!
Energizing the stator just makes the rotor drag because of bad bearings, worn shaft, worn sleeve, or bearing fit! Take your pick.
Ben Englund
Especially if it is a sleeve bearing and fresh oil has been added!
Bad bearings possibly could cause the capacitor to fail but good run caps can stay across the line all day long with no problems!
Slop in the shaft can be very hard to spot (I work on motors all day long and it can take a good minute to "feel" the slop in a bad bearing/fit in some motors).
The big clue for you is when you apply power the motor has "hard" spots that makes a metal to metal buzz.
When the bearings are good the only resistance you would have is a MAGNETIC type resistance to its turning. (This would feel similar to turning the shaft on a small hobby type permanent magnet DC motor)
General comments referring to product style at:
www.grainger.com/Grainger/wwg/viewCatalogPDF.shtml?CatPage=128
Permanent Split Capacitor — Band-/Stud-Mount — 5.63-inch OD — "Fan Duty" HVAC motor
NEMA Frame: 48YZ {old GE 39 fr}
In many cases...
Sleeve bearings are susceptible to wear and resultant shaft scoring—not usually economically repairable.
Replace motor if relatively small shaft sideplay is found. {Endplay is acceptable.}
Only reliable check running current compared to nameplate {with voltage/temperature/frequency in tolerance.}
Ben Englund
In a real pinch, engine-oil additive in the bearing felt may buy a little time.
