Pipe jacking size limitations
We are researching ways to place RCPs through an existing road embankment where an 8-foot diameter conduit already exists. Either two additional 10-foot ID conduits along side the 8-foot pipe or one 16-foot ID conduit are required to handle the flows. Hard, basalt bedrock may be encountered along the alinement.
Are there practical limitations on the maximum size of RCP that can be "jacked" through an embankment?
RE: Pipe jacking size limitations
Seriously, a 10 foot diameter pipe is within the limitations of the larger pipe jacking contractors. But a 16 foot pipe diameter may not be - in your area. Site and soil conditions have a lot to do with the success of this construction technique. Have you checked with the local pipe jacking contractors?
If you think that you may encounter basalt - even the weathered variety - along the pipe alignment, you would probably be better off with hand mining the two smaller shafts. Delays to the pipe jacking scheme could result in very costly extras - resulting in a much higher cost than hand mining. Something to think about, anyway -
Please see FAQ731-376 for great suggestions on how to make the best use of Eng-Tips Fora. See FAQ158-922 for recommendations regarding the question, "How Do You Evaluate Fill Settlement Beneath Structures?"
Zambo
