rotary dryer burner sizing...
Trying to calculate the burner size required to dry 7 MTPH of 18% humidity sand in a rotary dryer. The dryer has been sized for retention time = 1hr or 2.2m ID inside refractory x 15m LG on 1degree incline. Plan on 6" castable refractory lining. Anyone know how to determine the heat input required relatively accurately ?? Assume efficient seals :) MO
RE: rotary dryer burner sizing...
Do you know final humidity content in sand? Do you know maximun RH in air for this humidity content?.
Alfredo
They want the product humidity to be reduced from 18% to 0.5%. Not sure the RH - but client is in Costa Rica so i am gonna guess relatively high (~65%) ?
MO
MO
Fuel flow (Btu/hr)
Sand flow+sand water flow (he, Ce, Te)
Air flow , he funcion of (T & RH)
Your dryer outputs are.
Air flow , he funcion of (T & RH).
Air flow: You need RH and temp at dryer outlet to calculate this flow, with amount of water evaporated.
Do you feel 95% humidity leaving the dryer is a reasonable assumption at sea level ?
Mark
