looking to Identify aluminum alloy
I need an aluminum tube with very good reflective properties on the inside. It needs to have a mirror-like finish, but can not have a dark hue to it. The ideal that I have found has a misty type of finish to it. I have no alloy numbers, but I have had hit and miss results with the 3003 and 6061 alloys.
there are usually some suffix after these but I cannot relate them to anything in particular. Any attempts to pollish have resulted in a dark hue and this is an undesirable situation
RE: looking to Identify aluminum alloy
Here is a polish, Semichrome,  that works very well on Aluminum.
http://www.winterbrookfarm.com/restore.htm
Come back with a little more information as to the enviroment the tubing will see.  Normally 3003 would work fine and can be purchased with a relative smooth inside surface.   Any of the 6061 alloys will work but require more effort to polish.  The best alloy would be 1100-0 for polishing.
If weight isn’t a problem you can get internally  polished Stainless Steel pipe and tube.
For the aluminum alloys mentioned by unclesyd, and your intended service of the aluminum tube you might want to consider chrome plating the tube bore. I believe the ID surface would require a flash plate of nickel followed by a chrome plate that would provide a mirror finish.
id try to get a tube with high copper content 7xxx series that might give you reflectiveness you need.
