Importing DXF drawing views into catpart sketches.
I have a question on copying and pasting dxf views into sketches. When I select the geometry from the imported catdrawing and copy it to the catpart how can I manipulate the geometry to align it with the origin of the view to the origin of the model itself? The same goes for multiple views on multiple sketch planes, how do I make all of the views coincident or line up?
RE: Importing DXF drawing views into catpart sketches.
As far as aligning views, V5 has a way to align views that you've generated or created interactively. But I would just move the views manually and line them up by eye since your working with DXF data.
what i could suggest you is create a point at 0,0 coordinates in each view and then copy the dxf to catpart and align the 0,0 point in dxf to 0,0 of the catpart try this out it might work
amit
