plates perpendicular to each other
I am trying to model a structure made from plates and supporting bars. Think about 2 rectangular plates connected to each other by supporting plates and bars that are perpendicular to 2 plates. As far as I know, if I connect plates perpendicular directly on the same node, I end up with very flexible structure than real. Nastran manual says put a bar element at the corner to compensate. Do you have any suggestions or design tips for this analysis.
RE: plates perpendicular to each other
The problem which netjack has posed is an example of this very behavior. Imagine two flate shell structures, one of top of another, both with normal in the z direction. If I connect these two structures with a beam element which is oriented along z, there is no means in the "classic" shell formulation to react moment about z from the shells.
Most codes have some means of addressing this problem, either via "artificial" stiffness in this dof (often done automatically), or through automatically constraining this when it occurs.
Other ways to address this: connect to more than one element, or use elements to distribute these loads.
One other thing--
Although I am not a current Nastran user, I understand that MSC has recently introduced something called SNORM. One of my former colleagues has been playing with it. I have heard good and bad things about it, but it is my understanding that this in some way addresses issues with drilling degrees of freedom (although I think you may need to use K6ROT in conjunction with it). As I said, I don't know the details myself, so don't take this as anything definitive--maybe look into the user guide on this.
Brad
2. Plates parallel connect with bars rods etc. This opens up the drilling dof problem with the plate. You cannot use SNORM,K6ROT etc. to constrain a rod perpendicular to a plate. The rod ends need to be connected by a 'spreader' type of technique using rigid elements to transmit the drilling moment into differential translations in the plate wherever you choose. SNORM is a technique in Nastran used where the plates are essentially connected in the same plane, but small unpredictable angles between them introduce stiffness into the drilling dofs by terms coming from the adjacent edge bending stiffnesses. That means the drilling stiffness term which should be zero is non zero and cannot be eliminated by AUTOSPC. The result is a spurious small stiffness which may have effects ranging from negligible to mechanisms. SNORM 20 degrees seems to be a very robust default.
