Socket Weld Or Screw type valves for Hot Oil Pipes
Need some advice on the selection of valve joints ( Screw or Socket Weld) for Hot oil Pipes at 150degC at 1.5bar only. The pipes sizes required is Dia 1" and 1/2" and 11/2" Stainless Steel pipes seamless for a heat exchanger project. Should I used Valves with Screw type fittings or Socket weld type fittings. Is there any article that I can also refer for reference? Thanks
Leo(Singapore)
jyleo@singnet.com.sg
Leo(Singapore)
RE: Socket Weld Or Screw type valves for Hot Oil Pipes
If stainless is required socket welds could save you some headaches down the road. Naturally assuming competent welder-fitters.
Use only an Approved Piping Classification Specification with the full valve description and manufacture tag number.
you may find a reference at the following:
http://www.standard.no/acrobat/L-001/index.htm PIPING AND VALVES
or
WWW.PIP.ORG PIP PN01SA0S01
Piping Material Specification 1SA0S01
Class 150, 304/304L Stainless Steel, 0.000" C.A. Process
