IMPLIED INTERSECTION for ORDINATES????
I know you can do a basic dimension in Inventor 8 and select one line, move off the line and RMB and pick INTERSECTION and then a second line and dimension from that intersection. BUT is there any way to perform this same function with ORDINATE dimensioning??? Sometimes you need to set the origin to a corner that doesn't exist and you just can't do it....
::sigh::
::sigh::
~ Phlyx ~
RE: IMPLIED INTERSECTION for ORDINATES????
Ray Havermahl
Independent Engineering Labs
www.ielinc.com
