DWG TO DGN CONVERSION
I have a survey drawing in AutoCAD format. Our Surveyor works in AutoCAD only. Client wants the final drawings in microstation format. So...I want to convert the drawing we got from our surveyor into a microstation file. Then I can use that file as my base drawing in microsation to create all other drawings.What things I need to keep in mind. What is the process?? What mapping software
are available. How the survey points & other data gets converted?
I am having trouble in converting layers to levels, color tables plotting to line weight plotting, converting blocks to cells...etc etc.
Is there a standard method to do this...has anybody done it before. How does the various software available for autocad to microstation conversion works??? I sit really worht to but them??
Please send anytype of link/information related to this topic.
RE: DWG TO DGN CONVERSION
I am having trouble in converting layers to levels, color table plotting (autocad) to line weight plotting (microsation), converting blocks to cells...etc etc.
Is there a standard method to do this...has anybody done it before. How does the various software available for autocad to microstation conversion works??? Is it really worth to buy them??
Please send any type of link/information related to this topic.
file --> import dwg or dxf
there you find the neccessary tools and tables for converting a drawing. I do this all the time.
if you want more information on how to do just contact me.
h_molenbe@hotmail.com
P.S. i'm a dutch college so forgive me for my spelling
mvg
HMO
Good Luck!
