2004 Mechanical objects don't copy correctly.
When I copy a hole it moves or sometimes rotates when the copy command finishes.  It also asks if it is a new or existing hole.  I don't want it to ask, cause I don't care and I just want my holes and other objects to copy where I tell them to.
RE: 2004 Mechanical objects don't copy correctly.
Are you using the plain "copy" command or "copy move rotate" from the express toolbar?
