INTRLAINK QUESTION
INTRLAINK QUESTION
Hi All,
Is there a way to set modified files in Workspace, so if you check out higher level assemblies to the same workspace these modified files will not be override by the files checking out, or have to manually remove the files that you do not want to check out at the check out stage?
Thanks in advance for any suggestions
Tofflemire
Tofflemire
RE: INTRLAINK QUESTION
Its not that ideal but it will work.
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
im4cad
Pro Design Services, Inc.
http://www.cadproe.com/pds/home.asp
