How do you add a TAB to the Feature Tree in SW?
Has anyone here ever added a tab to the feature manager tree in SolidWorks?
I have done a reasonable amount of SWAPI programming and never really ran into adding tabs...
Is it possible with the SWAPI alone or do you need to be a cerified SW Partner and get special software to do so?
I assume it is not possible to do with VB (most likely VC++)
But I am a bit currious if it is possible for 'anyone' to be able to add a tab.
I have access to SW 2001+ and 2003.
I mainly use 2001+ at work and only use 2003 to teach night classes at a local TechCenter (VoTech)
Any links or info are appriciated.
Please post if you have similar request/needs and I will share anything I learn on this topic
When dealing with computers, there are 10 things you need to know: one, zero, and the rest is Binary.
-Josh S
RE: How do you add a TAB to the Feature Tree in SW?
I've gotten this from the help-files:
retval = ModelDoc2.AddFeatureMgrView2 ( bitmap, appView, toolTip)
But I hadn't had the time to try it yet. Please let me know the results
