shock absorbers
shock absorbers
i am looking for compact shock absorbers for a motorcycle. they must be strong but don't need to travel too much. this is just preliminary research so i do not have any calculations at the moment. i am more just looking for direction or a brand or something like that so i can start to determine specs and what not. any information you could provide on small compact shocks would be greatly appreciated.
thank you
thank you
RE: shock absorbers
Alex
RE: shock absorbers
RE: shock absorbers
RE: shock absorbers
J.C. Whitney has some for $80.
http://www.jcwhitney.com/webapp/wcs/stores/servlet/ProductDisplay?productId=5416&catalogId=10111&langId=-1&storeId=10101
RE: shock absorbers
If you need only a few, visit your local motorcycle shop, or as Mandrake suggests, find a junkyard with bikes.
Biker aftermarket go-fast shops and catalogs would also have a selection.
The formula Ford, formula Atlantic set also use some neat little dampers.
If you need lots, talk to Tokico, Sachs, Koni, Monroe, etc.
