Engine Configuration for new project
I have decided that for this years non-profit-fun-project I will make a set of patterns to make a new engine block, and or cylinder head. My problem is that after considering the many possible configurations I have not been able to settle on one design.
The following is a list of configurations that I am considering, please suggest any others that you think would be interesting or useful.
1. Four valve heads for the gen 3 (LS1,LS6) small block Chevrolet based on components from the Quad 4 head.
2. A V-12 (60 deg) version of #1
3. A V-12 (60 deg) version of a Big Block Chevrolet or 429 Ford SCJ
4. A revival update of the Offy 4, with narrower valve angles and higher ports.
Any ideas or suggestions appriciated.
Jonathan T. Schmidt
http://www.schmidtmotorworks.com
http://www.motorsportsdesign.com
RE: Engine Configuration for new project
How about a V8 block to accept a pair of Honda S2000 heads, or better still, a V12 block and 2 head castings to use the S2000 head components but stretched out to 6 cylinder, to give a V12 version of the S2000, which should be about 530 kilowatts, or about 700HP.
pat   pprimmer@acay.com.au
How about a 2000cc V8 motor based on the GSX-R 1000 or R1. I know one Uni built a V8 600cc motor for FSAE. If you build it you could make one heck of a go-kart next year.
is 5 valve an option?...
that audi 20v makes a pretty flat torque curve [seat of pants dyno;)]
Could u imagine a 40valve LS6?....
*drools*
But I think u'd do the Chevy guys a favor by building the 4valve LS6/LS1 heads.
Keep us posted
betton,
I think may have something there, I have been asking around the LS1 people and they seem to have some interest in a better head. I am going to have a look at some cars with ls1 in them to see if a 4 valve could be made to fit.
Best Regards
Jon Schmidt
Jonathan T. Schmidt
