Modifying the ADAMS config parameter from STANDARD to EXPERT
How do i go about this? I've tried the method within the ADAMS help (Modifying the ADAMS config parameter from STANDARD to EXPERT), but it doesn't work out. Do i need to do something else?
The second question is .... does anyone know where i can get any ADAMS tutorial on double wishbone modelling ... template? I mean, not the ones supplied in ADAMS, but to model a new template from scratch!! (to be more precise ... volkswagen beetle front and rear suspensions).
Any help will be appreciated, thanks all.
RE: Modifying the ADAMS config parameter from STANDARD to EXPERT
kisumu,
Please check the FAQ for this forum. You may find some help there.
Also, the Volkswagen Beetle does not have double wishbone suspensions at either the front nor the rear.
Best regards,
Matthew Ian Loew
"Luck is the residue of design."
Branch Rickey
MLoew
Thanks for your advice. The suspension i have in mind apparently came with the instructions ... V Beetle, ddle susp! But anyway thanks alot. I'll check out the info.
you can toggle using F9 but you must go into msc.adams and save i.e in acar save acar as .acar.cmg file in your c or home drive but check if its on standard if it is then delete standard and put in expert.
