Dimensioning Problems - TRUE?!
Whenever i try to dimension a radius or diameter of a part in a drawing, i get "TRUE O.45" or "TRUE O2.20". My drawing doesnt have enough room to be cramped up with 100 true's, is there any way to possibly get this off.
RE: Dimensioning Problems - TRUE?!
The problem here is that the system only puts in the word TRUE if the dimension is added to a view in which the plane of the arc is not parallel to the plane of the view.
If you do all the dimensioning in a normal orthogonal view you wont see the word TRUE unless the circle/radius is on a sloping surface as seen in that view.
Sadly I dont know of any way to avoid the TRUE entry when the circle or radius is being done 'out of plane'
I did scour the 'Format Standards' and 'Format Dimensions' but could not find a reference which might get rid of the pest which most international standards say should be there.
regards
Ralph Tilbrook
