Revision Blocks and Templates
We have settled on our standard for our title block and decided to remove the revision table and use the built in one with Inventor 8. We customized the layout of the revision block, added some fields and anchored it to our title block. When we OPEN this drawing file, everything is fine.
BUT when we save this drawing file as a TEMPLATE and start a new drawing using this template the revision table that is on the drawing is GONE! If you insert a revision table the fields we added are gone, the layout is back to the default and everything is as if we did nothing to the revision table. If you open the template drawing it's still there.
The question is, is there any way to have a DEFAULT revision table layout (and possibly location on a drawing) that you can have nested in a template drawing file????
Thanks in advance for any assistance!
~ Phlyx ~
RE: Revision Blocks and Templates
Sean Dotson, PE
Inventor Tutorials & More
www.sdotson.com
Your Webbased mCAD Discussion
www.mcadforums.com
I'm afraid not. I don't know if this is a bug or has just been overlooked....FOREVER. We have been opening our idw template file and then doing a save as. Then open the saved as idw & the revision table stays.
According to our reseller, this is something that he has been requesting AutoDesk to fix since Rev. 5.
---AUTODESK, PLEASE FIX THIS!!!!!!!!!!
..............................::sigh::
Sean Dotson, PE
www.sdotson.com
www.mcadforums.com
