'Hydroxite' as magic filter media
I am reading of a new and almost miraculous method for the filtration of water with the use of hydroxite as part of a sand filter media.  It comes 'equiped with retention tank and dula ionization and oxygen electrodes'. They are big on the Web with the name of Ecosmart.
Sounds like a snake oil thing or maybe they are simply stretching the results to make us think that it all capable of removing everything from water.
Please:  any comments appreciated.
Jim Porter
RE: 'Hydroxite' as magic filter media
If it sounds to good to be true it just might not be true.  Caution should be excersized when evaluating.  I did not see any "independent, disinterested, third party testing" indicated on the web site.  That would include NSF, UL, WQA or other testing facilities.  They do show a water analysis done by National Testing Labs, however, they do not show a "before" analysis. They also obliterated the "Customer Name and Dealer Name".  That analysis makes no reference to any pretreatment.
Gary Schreiber, CWS VI
The Purolite Co.
Thanks Gary:  I  spent some time on the web also. The original came from a company called ECOsmarte.  There was another that came in with the same line with a product called 'Eliminator'.
I have been teaching classes in water quality and energy for some time now and this one did smell of 'snake oil'.
Remember 'Evis'.?
Jim Porter
What is being referred to here is electro-coagulation. Basically using sacrifical aluminum or iron electrode to coagulate organics such as FOG, phosphate, varous heavy metals. The "oxygen electrode" is a reference to the increased DO that occurs from the splitting of the oxygen-hydrogen bond of the water where sufficient voltage is applied. EcoSmarte and others use hyperbole and rhetoric to make a very common practice sound like the greatest thing since sliced bread. Just a merging of electro-coagualtion and chlorine generation.
We deal with true electrolytic oxidation - no sacrifical electrodes, no chlorine generation. Where properly utilzied, saturation of DO- even supersaturation possible, as well as creation of numerous hydroxyl radical ions and other oxy-radicals.
The key here is the term "filtration" not oxidation/redox - because they are flocculating/coagulating organics.
Dave Orlebeke/Aquatic Technologies
