active suspension, parallel a-arms
Anyone know of any good research in the area (or related area) of using parallel a-arms with active suspension to try for zero body roll.
RE: active suspension, parallel a-arms
Cheers
Greg Locock
I see lots of research in adapting (semi) active suspension to traditional suspension designs, such as the use of magnetorheological fluid dampers in place of standard dampers. However not much in taking full advantage the flexibility active suspension could give to the overall design.
- Timoth
