Failed to initialise Visual Basic
It happened with few version of SldWks on different computers. I install the program, then trying to run it, the error message :
"Failed to initialise Visual Basic for Apps, equations and macros will not work. Are you low on disc space." v.2004
or "VBA init failed" in older version...
I have gigs of disk space. Can anyone help me?
Can it be because I have an AMD process?!?
RE: Failed to initialise Visual Basic
Try complete uninstall & reinstall of SW per FAQ559-488 & make sure AV is off.
What to do?
See http://www.eng-tips.com/faqs.cfm?spid=559&sfid=884&newpid=559 (Thanks Scott)
Does it ring a bell to anyone?!?
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
