VISUAL BASIC
VISUAL BASIC
VISUAL BASIC
I have one problem when I install Catia, because when I try to open Visual Basic Editor, this command It's unable to hit. I have reinstalled Catoa, 5 times....Anybody knows something about this??
RE: VISUAL BASIC
Hi IESBAD,
In case which VBA editor is not installed by default (it can happen to my experience, but the cause is still not known to me ... >_<), we should then install it manually.
   1. insert the install CD
   2. under the folder VBA
   3. run the vba6.msi
Cheers. Kennis Tang.
