File Transfer C: to Network
I might have to work at the remote location on my computer building assemblies on my hard drive.
I will be using copies of parts that are on my company's local network which I will have no access for.
When my assy is complete I need to send it electronically with all the components including subassemblies or send a CD so eveything can be put on the local network.
Files have different locations on the network.
How do I do it the easiest way?
I thought someone would copy all files including main assy to appropriate locations but then when he opens an assy SW will ask for the file locations ( they will not be on C: ( hard drive ) anymore and every single component would have to be searched at proper location on local network.
Could anybody give me some hints how can it be done the easiest way.
I believe it can be done, they worked on International Space Stations with hundred different locations and it worked, didn't it?
RE: File Transfer C: to Network
If you have all of the files in a single directory, SW will find them. Otherwise, if you have parallel structures, SW will find them. You can also use search directories.
http://www.EsoxRepublic.com
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
It is easier than I thought.
SW has an option to open and save files from the web site so you get get the access to the network ( I did not know it though )
