Torque for small screws taped into aluminium
Can someone direct me to reference table which list the recommended torque values for small, stainless steel installation or mounting hardware when mounting 6061 Aluminum Electronic part(s).
The size of mounting hardware typically used with our products is in the M2 to M6 size range.
Tuspi
Tuspi
RE: Torque for small screws taped into aluminium
and get the results you need with
just a little sampling. You might
have to drill a slightly larger
hole before tapping as the holes
may shrink after drilling. You
may also have to use extra heavy
washers so you do not create too
much bearing stress at this surface.
FAQ725-536
Cory
http://www.turula.com/bolt.html
http://euler9.tripod.com/fasteners/
You'll probably find the informations you're looking for in this Bossard website.
http://www.bossard.com/techinfo/en/index.html
Best regards,
ct
