Printer Setup in Pro/Engineer 2001
I do hope someone can help me?
Can anyone tell me how to set up pro/engineer 2001 so that I can use an inkjet printer.  At the moment the settings are pointing to a 'Postscript' printer which is currently a laserjet, however I want to change the printer settings to configure to my inkjet printer.  When I go to "Commands and settings" (In the "Print" dialogue box) and then to "Add Printer Type", it does NOT give me an option of selecting my required printer.
I am using a 'Windows' based platform and operating 'Windows 2000 Professional'.
I hope someone can help me?
nickr!
RE: Printer Setup in Pro/Engineer 2001
If I not mistaken when you print through proe you have access to "MS print manager". This way you should be able to print to any printer that is installed on Windows.
Joe Borg
www.methode-eur.com
