closed extension spring used as a beam
Hi Spring people.
There is any way to calculate the deflection of a extension spring used as a two bearing beam.?
¦ load
bearing bearing
Hope it is clear.
¦ load
bearing bearing
Hope it is clear.
Pardal
RE: closed extension spring used as a beam
I have not seen any formula for the application you mention,
however could a single rectangular leaf spring be better suited to your application if so I can help you there?
regards desertfox
Thanks any way.
Pardal
