Orifice in a vertical pipe run
Are there any special considerations for an orifice installed in a vertical run besides insuring the sensing lines are sloped down to the transmitter?
RE: Orifice in a vertical pipe run
rmw
Eng-Tips.com : Solving your problems before you get them.
On top of the previous comments bear in mind that the direction of the flow is important. This is depending on the medium going through the pipe.
A gasline the flow should be downwards.
A liquid line the flow should be upwards.
Dood luck,
Thomasjl
rmw
SFE
