OUTPUT : HY8 FOR CULVERT DESING
The output of HY8 program (from HYDRAIN family of programs by FHWA)gives you the "type of flow" in the culvert for different discharge values.
For example: 1-S2n, 5-S2n, 1-M2c etc etc.
What is the significance of these short forms. Does anybody has any idea where I can find the description of these short forms used for "type of flow" in the culvert.
I am sure there must be some FHWA publication which explains this...but I couldn't find it!
Please help.
Please help.
RE: OUTPUT : HY8 FOR CULVERT DESING
H(2,3) is for horizontal,
M(1,2,3) is for mild slopes (subcritical)
C(1,2,3) is for critical
S(1,2,3) is for steep (supercritical)
Best, Tincan.
http://www.fhwa.dot.gov/bridge/hydsoft.htm
Terry
I scanned HDS-5 and could not find the charts either. I have seen tables in many hydraulic publications. I found a decent depiction in the following document:
http://www.engineering.usu.edu/classes/cee/6500/GVF.pdf
It helped!
I needed a quick and concise depiction of this for a submittal. This will do.
Do you know if this is copyrighted data? I will just site the web address for now, but would love to give credit to whoever wrote/drew this.
Let me know.
