Are you an alumni?
Are you an alumni?
As I was driving to work this morning, I saw one of those "Univ of xxx Alumni" license plate frames.
They bug me because they presumably refer to the owner of the car, who is probably an alumnus of said university.
It probably bothers me mostly because I hear people say, "I'm a xxx alumni" or "I'm an alumni of xxx" when, of course, they should be using the singular form, alumnus, rather than the plural.
Just my issue...
Just my issue...
RE: Are you an alumni?
xnuke
Buy a dictionary, keep it nearby and USE it. Webster's New World Dictionary of American English is recommended, and Webster's Collegiate Dictionary.
I always thought that those license plate frames indicated financial support of the alumni association of a particular university...
datum / data
medium / media
In both cases, strictly speaking, one should use the "-um" form for the singular, and the "-a" form for the plural. However, both have effectively passed into common usage as singular collective nouns, and are even used as singular nouns on occasion. (I am not saying this is "right", but it has become so commonplace as to be almost standard nowadays. I will admit that I am "guilty" of adopting the modern common practice.)
For example, when referring to the news journalism industry, it is common to see "The Media is to blame for ...", whereas it should read "The Media are ..."
Other examples:
"This data point shows us that ..." Technically, you can't have a single data point, only a single datum, but common usage permits this.
"Select your preferred media for printed output." If you are only going to print the document once, you can only print it on a single medium. "Media" suggests that you will print it at least twice, on at least two different types of paper.
You're lucky EM, I'll get you next time
Yes, use "check out that one".
Cory
Winston Churchill once famously avoided the construction by finishing a speech with "..... up with which I will not put"
Good Luck
johnwm
The Winston Churchill episode that you mention was not originally in a speech (although it may have been repeated as such later). It was actually a marginal note that he wrote on a paper which a subordinate had written for him.
Remember that Churchill was a great champion of correct usage of the English language, and he was also a great believer in using "plain English" to express oneself even when dealing with complex issues. He is also remembered for his great wit, so it is widely believed that his note was meant to be read as dripping with irony. That is, he noted an instance of ending a sentence with a preposition which could easily have been rectified in the particular instance. However, rather than just marking the obvious correction, he chose to use an ironic construction to demonstrate that the pedantic following of "rules" can on occasion lead to constructions that are far more cumbersome than the technically incorrect version.
"I'm going to check out it."
doesn't quite have the same rings as
"I'm going to check it out."
"upbraid" checks out as well. Actually EM you know me well enough to know I'm just kidding about being out to get you, but your posts provide a multitude of words for me to look up. That's a good thing I guess.
You'd say "check it out," but you'd probably say "check out the new restaurant."
TTFN
Who could forget the superbly-crafted speech he delivered during the Second World War in 1940? I've posted the most memorable part below:
"...We shall go on to the end. We shall fight in France; we shall fight on the seas and oceans; we shall fight with growing confidence and growing strength in the air; we shall defend our Islands, whatever the cost may be; we shall fight on the beaches; we shall fight on the landing grounds; we shall fight in the fields, and in the streets; we shall fight in the hills; we shall never surrender..."
Magic stuff, made so much more memorable by the defiance in his voice as he delivered it to a nation on the brink of defeat. Dubya and Phoney Tony will forever live in his shadow.
Start each new day with a smile.
Get it over with.
Jesus is THE life,
Leonard
http://www.fpp.co.uk/bookchapters/WSC/Observer291000.html
This is something that few modern politicians would permit, although these same characters have no compunction about letting others write their speeches, something Churchill would never have countenanced.
That is a fascinating story, but I think it is only fair to point out that the link is on David Irving's site. It should be noted that David Irving is a controversial historian (to put it mildly). For example, he has been widely discredited as being a holocaust revisionist.
Of course, that does not mean that everything he says is wrong (or right, for that matter), but I would need to see this story reported independently by a less controversial source before I could accept it as fact. Intriguing, and just faintly plausible, nevertheless.
Full marks to EnglishMuffin for his comment on the curious inversion of speech writing and delivery but what would anyone make of it if Phoney Tony or Dubya routinely used doubles?
Footnote: Part of the deception of the Germans leading to the Normandy invasion was the use of a double for Montgomery (Clifton James? Clifton someone). Some tricky stuff including false fuel pipeline laying in North Africa.
I guess we are straying seriously now but why is the phrase "All's fair in love and war" but not "politics and war"? Interesting.
JMW
www.viscoanalyser.com
As usual, I have succeeded in leading this thread disasterously off-track. But there is one more comment that might be made about that classic speech of Churchill's. It was not quite as original as you might think. Compare it with this earlier version delivered on-air by the infamous Neville Chamberlain in 1940:
"We are a solid and united nation which would rather go down to ruin than admit the domination of the Nazis ... If the enemy does try to invade this country we will fight him in the air and on the sea; we will fight him on the beaches with every weapon we have. He may manage here and there to make a breakthrough: if he does we will fight him on every road, in every village, and in every house, until he or we are utterly destroyed."
So it appears that Churchill created his speech in very much the same manner that he wrote many of his books, which was to take what others had first roughed out and then rephrase, polish, and relentlessly prune all the prolixities and circumlocutions. People who helped him write his "History of the Second World War" were amazed at his ability to condense five pages into one. Perhaps it was his training as a journalist that enabled him to do this. None of his school teachers ever thought he would amount to anything, but interestingly enough, the same can be said of Hitler.
http://dictionary.reference.com/search?q=prolixity
n : boring verboseness
I think it's a noun which cannot have a plural. Would we say verbosenesses?
Sorry, didn't mean to interrupt the Churchill dialogue. It is interesting.
"I think of it as it should have been, with its prolixities docked, its dullnesses enlivened, its fads eliminated, its truths multiplied". So if you are going to take issue with me on this, you must also take issue with Fowler, who in his albeit much smaller world was as legendary as Churchill!
I think the answer could be yes -- if you have multiple personalities. Although I must admit, some of me do not agree.
In US lingo "It is a good read". jimbo
Guess it didn’t take.
Rick Kitson MBA P.Eng
Construction Project Management
From conception to completion
www.kitsonengineering.com
TTFN
