How do you get link excel spreadsheets to be unitless?
I am trying to get a stud spacing (unitless) for inventor.  My spreadsheet has the calculations for figureing the spacing based by loading.  I am setting up an assembly model to be completely ran by a spreadsheet.  All of the values being read by inventor have a inch unit and i want the stud spacing to be unitless.  Any suggestions?
Absolute zero has nothing on me!!
RE: How do you get link excel spreadsheets to be unitless?
Are you specifying the units in the Excel sheet.  The columns should be (from left to right)
Parameter Name, Value, Unit
If you leave the unit column blank it will default to length (in your case Inches).
Use "ul" (no quotes0 to make it unitless.
See my website for a tutorial on the subject.
Sean Dotson, PE
Inventor Tutorials & More
www.sdotson.com
Your Webbased mCAD Discussion
www.mcadforums.com
your tutorials on your website helped greatly, thank you!
