Right Click Menu
Right Click Menu
Right Click Menu
Can I change my right click menus or context senstive menus using lisp?  Something like if I preselected a text and right click I get a custom menu that I create just for text operations?  Like drawing a line and right clicking and getting the osnaps?
RE: Right Click Menu
You can change the right click action by changing the Menu file.  I've never tried using LISP to change it on the fly, but you could try using COMMAND "MENULOAD" to load a partial menu including the ***POP0 fragment.  My right click menu is as follows:
***POP0
**P0main
[Osnap]
[Zoom E]'Zoom E
[Zoom P]'Zoom P
[Zoom W]'Zoom W
[Pan]'Pan
[Set Osnaps]$p0=P0Osnaps $p0=*
[Non 0,0]_non 0,0
[@0,0]@0,0
[From]_from
ID_Tracking  [Temporary trac&k point]_tt
[$(if,$(and,$(getvar,osmode),4),!.)CENter]_center
[$(if,$(and,$(getvar,osmode),1),!.)ENDpoint]_endp
[$(if,$(and,$(getvar,osmode),64),!.)INSert]_ins
[$(if,$(and,$(getvar,osmode),32),!.)INTersection]_int
[$(if,$(and,$(getvar,osmode),2048),!.)ApparantINT]_appint
[$(if,$(and,$(getvar,osmode),2),!.)MIDpoint]_mid
[$(if,$(and,$(getvar,osmode),512),!.)NEArest]_nea
[$(if,$(and,$(getvar,osmode),8),!.)NODe]_nod
[$(if,$(and,$(getvar,osmode),8192),!.)PARa]_par
[$(if,$(and,$(getvar,osmode),128),!.)PERpendicular]_per
[$(if,$(and,$(getvar,osmode),16),!.)QUAdrant]_qua
[$(if,$(and,$(getvar,osmode),256),!.)TANgent]_tan
[$(if,$(=,0,$(getvar,osmode)),!.)NONe]_non
[.X].X
[.Y].Y
[.Z].Z
[.XY].XY
[.XZ].XZ
[.YZ].YZ
[Calculator]'cal
**P0Osnaps
[Snaps]
[Goto Dwg ]$p0=P0Main
[Pop 0]$p0=P0Main $p0=*
[Non]'setvar osmode 0 $p0=P0Main
[Add Snaps   ]
 [$(if,$(and,$(getvar,osmode),4),!.) CENter]'setvar osmode (+ (getvar "osmode") 4) $p0=P0Osnaps $p0=*
 [$(if,$(and,$(getvar,osmode),1),!.) ENDpoint]'setvar osmode (+ (getvar "osmode") 1) $p0=P0Osnaps $p0=*
 [$(if,$(and,$(getvar,osmode),64),!.) INSert]'setvar osmode (+ (getvar "osmode") 64) $p0=P0Osnaps $p0=*
 [$(if,$(and,$(getvar,osmode),32),!.) INTersection]'setvar osmode (+ (getvar "osmode") 32) $p0=P0Osnaps $p0=*
 [$(if,$(and,$(getvar,osmode),2048),!.) ApparantINT]'setvar osmode (+ (getvar "osmode") 2048) $p0=P0Osnaps $p0=*
 [$(if,$(and,$(getvar,osmode),2),!.) MIDpoint]'setvar osmode (+ (getvar "osmode") 2) $p0=P0Osnaps $p0=*
 [$(if,$(and,$(getvar,osmode),512),!.) NEArest]'setvar osmode (+ (getvar "osmode") 512) $p0=P0Osnaps $p0=*
 [$(if,$(and,$(getvar,osmode),8),!.) NODe]'setvar osmode (+ (getvar "osmode") 8) $p0=P0Osnaps $p0=*
 [$(if,$(and,$(getvar,osmode),128),!.) PERpendicular]'setvar osmode (+ (getvar "osmode") 128) $p0=P0Osnaps $p0=*
 [$(if,$(and,$(getvar,osmode),16),!.) QUAdrant]'setvar osmode (+ (getvar "osmode") 16) $p0=P0Osnaps $p0=*
 [$(if,$(and,$(getvar,osmode),256),!.) TANgent]'setvar osmode (+ (getvar "osmode") 256) $p0=P0Osnaps $p0=*
[Remove Snaps ]
[$(if,$(and,$(getvar,osmode),4),!.) CENter]'setvar osmode (- (getvar "osmode") 4) $p0=P0Osnaps $p0=*
[$(if,$(and,$(getvar,osmode),1),!.) ENDpoint]'setvar osmode (- (getvar "osmode") 1) $p0=P0Osnaps $p0=*
[$(if,$(and,$(getvar,osmode),64),!.) INSert]'setvar osmode (- (getvar "osmode") 64) $p0=P0Osnaps $p0=*
[$(if,$(and,$(getvar,osmode),32),!.) INTersection]'setvar osmode (- (getvar "osmode") 32) $p0=P0Osnaps $p0=*
[$(if,$(and,$(getvar,osmode),2048),!.) ApparantINT]'setvar osmode (- (getvar "osmode") 2048) $p0=P0Osnaps $p0=*
[$(if,$(and,$(getvar,osmode),2),!.) MIDpoint]'setvar osmode (- (getvar "osmode") 2) $p0=P0Osnaps $p0=*
[$(if,$(and,$(getvar,osmode),512),!.) NEArest]'setvar osmode (- (getvar "osmode") 512) $p0=P0Osnaps $p0=*
[$(if,$(and,$(getvar,osmode),8),!.) NODe]'setvar osmode (- (getvar "osmode") 8) $p0=P0Osnaps $p0=*
[$(if,$(and,$(getvar,osmode),128),!.) PERpendicular]'setvar osmode (- (getvar "osmode") 128) $p0=P0Osnaps $p0=*
[$(if,$(and,$(getvar,osmode),16),!.) QUAdrant]'setvar osmode (- (getvar "osmode") 16) $p0=P0Osnaps $p0=*
[$(if,$(and,$(getvar,osmode),256),!.) TANgent]'setvar osmode (- (getvar "osmode") 256) $p0=P0Osnaps $p0=*
