"Cycle color wheel" only give 4 different colors. I want more!
I have the option 'cyle color wheel during part creation' enabled. But it only gives 4 colors (orange, golden orange, red, and magenta, color # 9 until 12) instead of the 15 colors that are available in the color palette. Does anybody know how I can get more colors in the part creation proces than the 4 that I have now?
Any help is appreciated.
Roy Munnichs.
RE: "Cycle color wheel" only give 4 different colors. I want more!
I don't know the answer to that one.  I know you can turn off your color wheel, in your Options-preferences Modeler/Assembly cycle color wheel.
I would like to know the answer to this one myself. . .Anyone?
When you go to Options -> colors, how many colors are listed there? On that same form, how many colors do
you see when you click the "Fixed Colors" button?
Does the "color cube" look right?
Can you create new colors?
Blue = [red=0,green=0,blue=100]
Cyan = [red=0,green=100,blue=100]
When I do both things you ask, I can see 15 colors. An I can create new colors, but the color wheel only gives 4...
I found out there is no fix for this yet,
there is a PIR issued to this
problem, PIR#4706792
