Wiring Standard
Wiring Standard
Wiring Standard
Does anyone know if there is a published standard that provides guidelines for routing process signal wires (4-20mA)? This would be as opposed to power wiring (e.g. route signal wire in separate conduit, separated by a distance...). Thanks.
RE: Wiring Standard
I recommend you take a look at NFPA 79. It is the standard used to Electrical requirments of Machinery.
Christopher Caserta
ccaserta@us.tuv.com
Ph:904-225-0360
