WROT Copper Reducer
WROT Copper Reducer
I am in search of an odd WROT Copper fitting that I have been unable to locate. I need a copper reducer, cup x fitting (CxFtg) in sizes 3x2.5in. and 3x2in.. I am using type āLā copper pipe with 175psig max. working pressure. Does anyone know where I can find such a fitting? Any help you can provide will be greatly appreciated.
Thanks.
Thanks.
RE: WROT Copper Reducer
Check with any "larger" plumbing supply distributor.
What I mean by larger is not a mom and pop hardware store that has some copper.
Find in your area where the plumbers go to get their pipe when they have a big job, not just when they need a fitting or two. You should be able to find them there.
