Thermocouple adhesive
I am trying to find an adhesive to attach a thermocouple to a GRP plate. I was considering sodium silicate adhesive which can hold at high temperatures but is not very flexible, which is a problem as the plate will be flexing. I've heard that mixing this with ball clay can produce a flexible adhesive which will hold at high temperatures. Has anyone tried this or any other method for a similar application.
RE: Thermocouple adhesive
Here are two sites that may have the ceramic adhesive you need.
http://www.aremco.com/index.html
http://cotronics.com/vo/cotr/
If you want to try epoxy try this one.
www.masterbond.com
ER
Cheers
Steve
