Plotting in a Standard Text Height
How do I set the Text Height to be the same wether the scale is 1:1 or 1:700.  Also how do i do the same w/ any inserted blocks.  thanks, joe
RE: Plotting in a Standard Text Height
joe,
are You working with mspace and paperspace? If yes, You can insert the text and the blocks into the paperspace. You have to scale the drawings in the viewports. Plotscale 1:1.
regards, Lothar
What release?
