non-destructive investigation / bore scope
Does anyone have any recommendations for firms in the Washington, DC area that provide non-destructive investigation of existing buildings?  We are investigating a vibration problem associated with concealed ductwork.  I am specifically interested in using a firm that uses a bore scope (fiber optic camera with integral light) in order to avoid the Owner having to demolish large openings to get direct access to the duct above and below the floor slab.
We believe the problem is caused by one of 1) contact of the duct to the building structure (a composite steel frame); or 2) the duct is flexing excessively (damaged integral stiffener?); or both.
RE: non-destructive investigation / bore scope
Try Law Engineering in Baltimore, MD or Chantilly, VA
Please contact me in Seattle, WA if unable to find anyone interested in helping.  This is a area that my company specilizes in.
Gregory G. Schroeter
Manager, NDE Services
AMEC Engineering
11335 NE 122nd Way Suite 100
Kirkland, WA 98034
800-659-0488 ext. 3050
gregory.schroeter@amec.com
AMEC Earth & Environmental
Construction Services Division
1592 Rock Creek Ridge
North Bend, WA 98045
425-831-6888
Cellular 425-766-4354
Check out AMEC at www.amec.com and Earth & Environmental at
http://ee.amec.com
I/m in Philadelphia and need to look into the flooring
of an old building, with some kind of fiber optic camera rather than harming the floor.  Do you have any sources for this kind of work.  I noticed you were look for the same issue a while ago.
Jim Crowell
Crowell Design
Radnor, PA 19087
610 527 7760
designer@voicenet.com
