How to draw a involute line under Acad 2000
I don't know how to draw a involute under Acad 2000,anybody can give me some advice on this? many thanks
RE: How to draw a involute line under Acad 2000
There a simple example of drawing circle involute via LISP:
(defun c:involute(/ plist fi old_osnap cent rad xp yp eang)
  (setq plist (list "pline" 'command)
    fi 0.0
    old_osnap (getvar "osmode")
    cent (getpoint "\nSpecify center of invotute: ")
    rad (getdist cent "Specify circle radius of involute: ")
  (initget 0)
  (setq eang (getangle cent "Specify end angle <360>: "))
  (if (not eang) (setq eang (* pi 2.0)))
  (repeat 24
    (setq xp (+ (car cent) (* rad (+ (cos fi) (* fi (sin fi)))))
      yp (+ (cadr cent) (* rad (- (sin fi) (* fi (cos fi)))))
      plist (cons (list 'list xp yp) plist)
      fi (+ fi (/ eang 24.0))
  (setq plist (reverse (cons "" plist)))
  (setvar "osmode" 0)
  (eval plist)
  (setvar "osmode" old_osnap)
  (command "PEDIT" (entlast) "F" "")
  (princ)
Regards.
the true involute of a circle is the involute funtion as
inv (alfa) = tan (alfa) - alfa.
for alfa in radian and alfa is the pressure angle of the gear.
so for a given circle , you have as many involutes as alfa´s choosen.
I have a exel file to make a script file to load on acad and a LISP program to do the same .
Due a virus attack my pc is out of order until nex week . then I will be able to sen it if you want to.
Pardal
