toolbox browser not showing in feature manager
I'm new to using toolbox and need some help. The browser tab to access the toolbox components is not showing up in the feature manager. I DO have both Toolbox entries enabled in the "add-ins" menu. The "Toolbox" menu is showing up in the top file menu. I'm using SW Office, 2004, SP 2.1.
Thanks for your help.
RE: toolbox browser not showing in feature manager
When you have just a part document open, you can use the pull down menu to create CAMs, or experiment with the Bearings or Structural Steel Calculators, as well as configure your standards and Toolbox user interface.
DesignSmith
www.DesignSmith-Services.com
